Complete and Utter Noob here - Recv my machine but have not had a chance to put it together so if I get a reply of " go build it and play with it first!" I’m ok with that answer
But here goes. From what I understand - Create is used to create your project and generate gcode. Motion then takes the gcode and sends it to the machine. If I wanted to use something like Meshcam or VCarve - those programs would replace Carbide Create (I.e. - I design my project in Meshcam or VCarve) and then export to gcode and still use Motion to bring up gcode and send to Shapeoko controller. Correct? I am looking to do basic stuff like signs, some parts (tool holders as an example) for my workshop, small boxes. would also like to import images/photo’s (been looking at the various means of doing that) and create carvings of those.
- How suited to those types of applications is Carbide Create and what is it’s ease of use/learning curve to Meshcam and/or VCarve.
- In terms of Meshcam and/or VCarve - Meshcam has their normal version and a Pro version. VCarve has desktop and pro. If you had to recommend one of those two - which one and why (or why not)
- Suggestions on any other alternatives?
Any feedback is appreciated up to and including - come back when you’ve done some actual work!
Thanks again!
