I’m about to install 4.17 so I can enable the “Use HDZ” option. Is this option modifying my GRBL settings, or is it changing something somewhere else?
Installing Carbide Motion 4.17 replaces the front/back-end Carbide Motion 4.16 (or earlier) application on your computer — it doesn’t change the version of Grbl which is installed on your machine’s controller, and it shouldn’t change those settings — but you will have to update the machine settings as part of the HDZ install/configuration process.
actually the option will set the correct GRBL settings for the HDZ
so this does the magic for you
Been awhile since I visited these forums… What’s an HDZ?
Heavy Duty Z-Axis
