Carbide Motion 575 Bug (Help Please)
I am using the current CM 575 in conjunction with CC 743. On multiple occasions today and yesterday about 3 minutes into the surface job my shapeoko XXL loses connection and stops. I shut down everything, reboot computer, CM and if I don’t completely unplug the machine, I get the error no GRBL found. Once I unplug everything it will go through proper start up, initialization and begin the work was loaded. Then a few minutes later does the same thing again. Can someone provide me with some guidance Please?
Al
Usually this sort of thing is caused by EMI — please try running an “air job” where you leave the router and dust collection off, and remove the stock after setting zero a little high relative to it and let us know how this goes at support@carbide3d.com and we’ll do our best to assist.
Thank you I will give it a go
