I made a model with Fusion 360 and created three *.nc toolpaths: Pocket, Trace and Contour. The Pocket and Contour files route fine using Carbide Motion. However, when I try route the Trace.nc file, then Shapeoko moves the Z axis higher than mechanically possible (making the step motor slip for couple of seconds), then XY axis move correctly to the starting position, then then the Z axis moves way too far down and buries the V bit deep into the wood instead for making a shallow V-Groove.
I tested my toolpaths in the Fusion Simulator before I did the Post Process and it routed as expected making shallow V groves on top of the material.
Has anyone had same problems when using the Fusion Trace?
How can I trace this problem… is the problem in Fusion 360, Carbide Motion or in the Shapeoko firmvare?
Btw: I am using Shapeoko 3 XXL with Z-Plus and Carbide Motion build 521.
I hope you can help me figuring this out,
KHV
