I am trying to set up my bitsetter. When I am on the jog/page, the arrow keys do not work. I have a touch screen computer and those arrows do not work either, neither to d arrow keys on my computer work to move the router. They keys work in other programs, just not this one.
The router moves when I use rapid positioning, but other than that, I cannot get it to move.
Please note that the keyboard shortcuts for Jogging only work when that pane is active and has focus. If they still don’t work then, please let us know step-by-step: what you did, what you expected, what actually happened and we’ll do our best to sort it out with you.
I am not sure what is meant by has focus, but I am in the window that I would job the machine, otherwise I don’t need the arrow keys.
I had a laser attached to the router. I removed the router ( I used Lightburn as the software for that) then when I went back to use the CNC router, the arrows no longer worked. No sure if that is just a coincidence or one actually affected the other.
I di nothing else to the machine that would cause this to happen. I have noticed that when the bitsetter checked the z axis, it touches the probe then on the second touch, the increments at which the router is lowered it extremely slow.
Did you re-flash when using Lightburn? If so, you should re-flash back to an installation of Grbl which has the Carbide 3D settings — contact us at support@carbide3d.com for the specifics.
