I’m running fusion 360 generated gcode on a nomad 883. I keep getting errors when I run code. Everything from “probing cycle failed” which happens occasionally to “Expected command letter G-code words consist of a letter and a value. Letter was not found” and “word repeated or command not expected. In valid code.” Which I get every time I’m running some parts. Some times i reload the program and it works sometimes not. Code looks fine to my untrained eyes. So is this a software issue?
Are you using the setup as described at:
If so, let us know at EDIT: fixed address: support@carbide3d.com and we’ll do our best to help.
Definitely running defaults. I’ll contact help desk.
So I copied the email from your post but it bounces.
My thanks to @Hooby for correcting my typo in the e-mail address.
