Carbide Motion keeps losing connection
Trying to cut 21 inch diameter in red oak game board 3/4 inch thick. Tried over and over. Cutting in 7 passes at very slow rate with new bit.0.25 endmill.
Have you tried the usual suspects?
- router and vacuum on separate circuit from machine and computer
- vacuum grounded
- if in a dry area run a humidifier or spritz the material w/ water (on both sides for wood) before cutting
If not, contact us at support@carbide3d.com and we’ll do our best to work through this with you.
Problem worked itself out.
Thanks for your effort!
Stopped current task and went to another with no problem. Returned to problem task and it worked just fine!
