downloaded Carbide Create/Motion build 51
Create appears to open and create, but Motion opens but will not respond. If you click on Connect to cutter i get message "cutter not found. If i click on anything else it will show that it was clicked on but nothing opes (like RUN…MDI…SETTINGS) I am running Windows 7 Ultimate. I did try afew older versions of Carbide Create with no luck
If i open the Motion folder there is nothing in it(completely blank)
We haven’t supported Windows 7 since it was end-of-lifed by Microsoft 14 January 2020 — some folks (including some who have paid for extended support/patching) have been able to use it successfully, but if it doesn’t work, it’s not something we’re in a position to assist w/
Please try running the program on a supported computer setup — if you have any difficulties w/ that, let us know at support@carbide3d.com and we will do our best to assist.
If your machine is an older one still running Grbl 0.9, then you can use CM366/368 from: https://carbide3d.com/downloads — contact us at support if you want to update it.
