I am in sort of a bind here. I am trying to run Carbide Motion 618 so that I can use the commands in the following troubleshooting guide to bypass my homing switches until I get some replacement parts (Troubleshooting Homing) The problem is CM618 keeps locking up and going into “Not Responding”. I have uninstalled, rebooted, re-installed
CM582 runs fine however it will not accept the commands out of the above mentioned article. So I am stuck again at the moment. Anyone run into any issues on 618. The machine is the following specs
Windows 10 Pro (64 bit)
16Gb RAM
Intel i5-6500T 2.5ghz
All windows updates applied
no AV running
plenty of storage.
Again 582 runs fine I just cant seem to use the commands to bypass the homing switches. Which I need until I get my replacement parts.
