We’re looking at some changes to Carbide Motion and we always end up trying to figure out how much we can/should pack on the screen. Your answer to the question below would be helpful in settling that persistent internal debate.
No screengrab, since I don’t know how to do that on an rPi (and it only boots up when running the machine), but 1280 x 800 - 10.1 inches here is my most frequent use-case.
EDIT: also, the 16" Samsung Galaxy Book 3 Pro 360 isn’t an option in the above which is conspicuously missing displays in between 15 and 17 inches.
I’ve got a couple of rPi’s - one with a 7" & the other a 10" touchscreen display. After using each, while I like the concise size of the 7", the 10" is a more appropriate minimum screen size. Especially for a touchscreen.
I use one of two; a 7" RPi touchschreen and a 32" 4K monitor on a Mac mini. Which i use depends on what I’m doing at that time as the Mac mini is also my work machine and my interface to my laser cutter.
@robgrz I was excited to see the question when it started…and then my heart fell a little when I saw that the question was about screen size. Design trumps screen size, in my opinion. You can pack a lot in a small space and make it highly usable, if the design is right. Size isn’t the issue.
Pack as much function as you can into CM - and get a UX specialist to make it usable. Don’t sacrifice function.
I use a Surface Tablet to run my machine but I wouldn’t let that stop you from adding other features. If I need stronger readers I can buy them. I’d love to see more man readables, better 3D representations, ect…
I would add that besides size of the screen - usability considerations for touch vs. mouse vs. fob is critical. What functions are available via touch - where “right click” is not very easy - and drag-and-drop is a little more complicated? Supposed you primarily use a fob (or remote keypad) and still need hotkey support - does that change the design?
What an interesting poll. I wonder if there is a gap between those who do both CAD/CAM and CM on the same PC (thus driving the larger screen sizes) versus those who use a separate PC just to run CM. I have an old PC with an old VGA 12” screen next to my machine but CAD/CAM on a much better PC with a 22” HDMI widescreen.
