Carbide motion won’t load “MSVCP140.dll not found” Downloaded program and set up but got this problem Thanks
For MSVCP140.dll missing see: https://www.microsoft.com/en-us/download/details.aspx?id=48145
For more recent versions try: https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads — note that it may be necessary to install both x86 and 64-bit versions.
Thanks, that got everything going. I need to look at one more thing, the fast positioner only steps in the amount selected for regular movement. I need to look at this, It may be me, been doing 4.5 things at once including replacing the 16 led strips in my 70 inch tv
Yeah, found a place that explained hot to load this and it went OK. Thanks
As @WillAdams mentioned: Make sure to install both versions: x86 & x64!
I read past that and only installed x64 (since I’m on an x64 system) which didn’t fix the issue.
Works well now. Thanks!
