I just upgraded my Shapeoko 3 from grbl 0.9 to 1.1h using the Arduino IDE and the stock config.h file - I didn’t use the Carbide updater. I then corrected the grbl defaults to match the Shapeoko ones. When I open the latest CarbideMotion 4 I get this error:
ERROR (1): GRBL ERROR: Unsupported or invalid g-code command found in block
I can still connect, home, jog, and probe. Haven’t tried executing a code file yet. Here are my grbl defaults:
$0 = 10 (Step pulse time, microseconds)
$1 = 255 (Step idle delay, milliseconds)
$2 = 0 (Step pulse invert, mask)
$3 = 6 (Step direction invert, mask)
$4 = 0 (Invert step enable pin, boolean)
$5 = 0 (Invert limit pins, boolean)
$6 = 0 (Invert probe pin, boolean)
$10 = 255 (Status report options, mask)
$11 = 0.020 (Junction deviation, millimeters)
$12 = 0.010 (Arc tolerance, millimeters)
$13 = 0 (Report in inches, boolean)
$20 = 1 (Soft limits enable, boolean)
$21 = 1 (Hard limits enable, boolean)
$22 = 1 (Homing cycle enable, boolean)
$23 = 0 (Homing direction invert, mask)
$24 = 100.000 (Homing locate feed rate, mm/min)
$25 = 1000.000 (Homing search seek rate, mm/min)
$26 = 25 (Homing switch debounce delay, milliseconds)
$27 = 5.000 (Homing switch pull-off distance, millimeters)
$30 = 1000 (Maximum spindle speed, RPM)
$31 = 0 (Minimum spindle speed, RPM)
$32 = 0 (Laser-mode enable, boolean)
$100 = 40.000 (X-axis travel resolution, step/mm)
$101 = 40.000 (Y-axis travel resolution, step/mm)
$102 = 40.000 (Z-axis travel resolution, step/mm)
$110 = 5000.000 (X-axis maximum rate, mm/min)
$111 = 5000.000 (Y-axis maximum rate, mm/min)
$112 = 5000.000 (Z-axis maximum rate, mm/min)
$120 = 400.000 (X-axis acceleration, mm/sec^2)
$121 = 400.000 (Y-axis acceleration, mm/sec^2)
$122 = 400.000 (Z-axis acceleration, mm/sec^2)
$130 = 425.000 (X-axis maximum travel, millimeters)
$131 = 465.000 (Y-axis maximum travel, millimeters)
$132 = 80.000 (Z-axis maximum travel, millimeters)
How do I get rid of this error? Do I have to modify the config.h file and refresh? If so, are the changes needed in the config.h file documented somewhere? Thanks!
