I can’t open Carbide Motion 5.0. I used Windows 10 Pro and I tried to upgrade Microsoft.NET and Graphic Drive but I still have same problem. Please help me. Thanks
Hi @vietghost,
You should contact support@carbide3d.com about this if you didn’t already, they will probably ask to collect specific log files about your configuration and then have recommendation about what to try.
Did you try to run Carbide Motion as Administrator ? (find Carbide Motion in the startup menu, right-click, “Run as Administrator”)
