Often one can’t help but draw up the image of the desired part — even when this isn’t the best way to cut the part in question out — consider the case of a scalloped edge as a decorative element along the bottom of a table apron:
duplicate the design and drag the duplicate into alignment, then draw in a rectangle representing the working area, select it, and shift-click on one copy of the design to make it the key element:
