Draw a 2.73 circle
draw a rectangle inside that circle
align rectangle to left inside edge of circle
use boolean subtract to make circle look like this
for the record… does exactly the same thing in VCARVE PRO - however i can at least go back to it’s diameter and change it from 2.728 height and 2.73 width to 2.73 uniformly. CC does not function this way. When I go back to edit said diameter, when I enter height and width as 2.73, hit apply, then some other arbitrary number is now in both cells.
Odd behavior… would think a set diameter is a set diameter. How does conjoining a rectangle affect the diameter of the previously set circle?
Shouldn’t have any effect on the height; however, you do lose a very small amount in width. Did you look at the size of the circle after drawing it and before the boolean operation? It could be that boolean operations convert the circle to a polygon so it’s like measuring a hex nut across the flats vs. across the points.
That should be correct — once that is removed it is no longer a circle — you could use Pythagorean’s Theorem to calculate how much is removed — here’s a visual:
yep did just that in a test and it worked out perfectly however didn’t go back to original measurement of 2.73, i did have to set it but it stayed this time.
