I recently downloaded CC461 and wanted to look at the formatting of the .nc file using inch format. While “dry running” it I noticed that after the tool change it moved in rapid to a Z coordinate and fed to its first X/Y location (that’s not good). On inspection of the code the “preposition” X/Y coordinates are missing. I am new to this, did I overlook something simple?
I like the addition of the “safe Z position” in the code. Since I don’t see it in the code at the end of program (but it does it) I assume it has been added to the M02 function. TEST.c2d (8.5 KB) TEST.nc (669 Bytes)
As far as I can tell (regenerating both the mm and inch version of your project), there is no influence of the units on the generated code (just the values, obviously)?
There are indeed no X/Y repositioning at the beginning of the second toolpath, but they would have been G0Y0.750X0.750, and the last X/Y commands that happened to be executed by the first toolpath were
Y0.750
X0.750
so…it does not change anything ?
I guess the final retract to top Z height (minus mm) is hardcoded behavior in CM, probaby triggered by M02 (end of program) indeed.
