In the Toolpath view, right now I can Copy and Paste, but I can’t delete items.
If I can do the first two, I should be able to do the third. Or, since it is the Toolpath view, don’t allow Copy and Paste.
It should only be possible to select/deselect in Toolpath view — moving and deletion are supposed to be disabled, and it is an interface inconsistency that one can copy/paste.
Go back to the Design view — deletion should work as expected there, and ctrl x should work to remove objects, while allowing ctrl v to paste them.
