Hi all,
I’m starting to use Pro and have a few questions. My stock is 22 mm thick which is reflected in the job set up. I imported my SVG file into design and added a rectangle for the border border and inside displacement for the pocket. Then go to model to create the components.
I highlighted the outside line to create the Stock Material ( height 22 mm, name materials, add, base height 0.000).
I highlighted the inside line to create the pocket ( height 10mm, name pocket, subtract, base height 0.000).
I highlight the image (round, height 9mm, name image, subtract, base height 0.000).
It’s not clear to me what the difference between thickness in job set up and height in the shape parameter?
When I go to toolpath and select 3-D rough and select the image I noticed there is a perimeter stock to leave how does this relate to previous parameters?
Thanks John
Sorry I don’t understand. When looking at the tutorials they suggest that you create a component the thickness of your stock then using this component as an Offset (Add or Subtract) to Create other Components. i’m not sure why this step is necessary as the thickness has been previously defined in job setup.
John
