CC will not accept Y dimension for work size
I am trying to set up a work surface x= 4.5 Y= .75 inches but CC keeps the Y dim at .9843"; it will not accept my Y entry of .75", frustration is setting in.
I have build 778 loaded, Win. 11 pc.
The minimum dimension is 25mm.
I guess you have a topic for the next revision. The limit should be .001" , the resolution of the screws.
Make stock dimensions 1" x 4.5", zero lower left corner, make layer, draw a .75" x 4.5" box, move it to the left, lock layer. Use that drawn box as you work area.
