Chamfer/threading advice?
Chamfering before hand tapping threads makes a lot of sense, it really helps get the tap started easily, thread milling, not so sure.
Thanks @BartK… This will be great reference file.
Any recommendations on thread mills / sources?
Recently purchased some of these and they seem to work great.
@BartK Could you share the cutter settings that you entered for the tool in fusion 360? I bought some of the same thread mills and now that I’m looking at the specifications I’m a little confused by the ā€œEscape from the skyā€ dimension…
Even better, if you could share some project that is using the thread mill then I could reference the actual machining operation. I’ve never used a thread mill before and getting it right looks like I need to learn some more!
Chris, did you see my previous post? I did attach a file with all the info you’re asking for.
@BartK nope, I totally missed the f3d.zip file up there. Doh! That’s exactly what I was hoping for. Thanks!
