Using V8 I started a cut and after a few minute realized I installed my old Vee bit and wanted to replace to new one. How do change a bit during a cut? Without restarting the entire cut? Thanks for any info.
This would only work if you could be certain of installing the new tool so as to have the same tool length offset as the previous tool.
Quit, reinitialize, change the tool, and if need be, re-set zero with the new tool.
Thank you, that’s what I thought, was hoping there was an easier (lazy) way to do it. Replace tool button? Haha Thanks again
