Change bitsetter position CM
Hi,
I’m on CM 635 and I notice that my cutter no longer aligns with the center of my bitsetter.
I have two questions:
  • Is it normal that I have this offset? I think it’s due to the use of my CNC.
  • How do I reset the coordinates of my bitsetter in CM? I can’t find the option.
Thanks a lot :slight_smile:
Bobi
Ideally it would be perfectly centered — a crash or shift in position of a homing switch can change this though.
If the machine is mechanically sound and square then re-do the Machine Setup Wizard:
https://my.carbide3d.com/
Thank you William,
Do you know, how can I change the position in CM ?
Thank you !
Best regard
Bobi
My understanding is that one first moves to the default position, then jogging is enabled, then one can move to the BitSetter and set the position there — if that doesn’t work, check in w/ support.
Although I’m sure this is not the correct way to make an adjustment one could open the shapeoko.json file with a text editor and make a minor adjustment to these two lines:
