Changing limit trigger
Is there anything I need to know to change a
S4 Y limit trigger ?
It should just be two screws and the connection.
Power down to do it. Note that unless you can exactly reposition the replacement the zero will be off, so if a you have a part clamped make sure that there’s a reference on it you can use to re-establish zero.
To the support staff at carbide 3D for all the help with my machine. Problem solved running great.
