Anyone have any input on changing over to Mac OS from my Windows laptop for Carbide create and Carbide Motion. What things should I expect? What benefits or challenges to expect. Please any input will be appreciated.
It should “just work” — the notable difficulty is if using files from Windows which have text if that text is set in a Windows-specific font — otherwise things are the same aside from using command instead of control for keyboard shortcuts.
Don’t forget to run setup new machine on the Mac before running your CNC.
It works just fine. No issues
The only challenge you may run into is moving over non C3D tools in CC from the Tool Database, if you have any. You could manually reenter them or copy over the .csv file from the windoz machine.
Thanks for all the guidance. Looks like a a gift under the tree this Christmas! Thank you again
