I’m new to Carbide Create and I’m wondering how I can change the size of multiple identical vectors at the same time (circles in this case). I can select multiples but then it gives you the total dimensions of the whole selection. Any help would be much appreciated! Thanks.
At this time, Carbide Create only affords an option to scale the entire selection (and the relative positions) as a whole — it is currently necessary to select each item sequentially and scale it.
This is clunkier but you can select all and do an offset. You would need to know precisely how much bigger/smaller you want. However the original objects are still there so you would need to delete them. If only offsetting a few thousands they two objects will be very close together and you have to zoom in a long way to clearly see both so you can delete the unwanted one.
