Cheat Sheet for the Shapeoko 5 pro?
Is there a Cheat Sheet for specific to the Shapeoko 5 pro? I have the one for the Shapeoko 3, but can’t find anything for the Shapeoko 5 Pro? Anyone knows about one? thank you.
Post the cheat sheet contents and see if people can help fill it out
Yeah we have no frame of reference for what you’re interested in as a cheat sheet? Is it like telling you when you want ramped cuts or speeds and feeds for unlisted/tested materials, pushing things beyond what C3D reccomends, slowing things down for perfect finishes?
The basics of operation are much the same for any machine.
The SO5 Pro does have some differences in the mechanics of movement and how they are verified (write in to support if you need our movement guide PDF for troubleshooting).
I wrote up a bit at:
Let me know if there’s something there which you think is missing, of if there’s anything which should be added to or updated.
This is a good start.
https://carbide3d.com/hub/courses/getting-started-cnc/
If you already have a Shapeoko 3 I don’t think there is going to be that much difference between the two as far as function is concerned. I dont own a 3 but i’ve watched tons of YouTube videos that used them.
