Checking offset distance
once you set an offset, can you later come back and see what offset was set. I am making boxes and have the template saved. but now want to check the ofset.
You would have to measure the distance between the sides — use the measuring tool or draw a circle.
Post the file if you have difficulty with this.
Circle worked the best…checking on 2MM. tx
