After 2 years of owning my machine I have finally crashed it.
Scenario: I was milling a relatively tall piece of stock ~2.5" along Z. This is a production piece I routinely make so the CC files are tested and proven. HOWEVER, the last time I ran this file I encountered a disconnect and modified the offending contour path to start at the depth already cut. As you may have guessed, I did not save this modified file as its own nor did I remember to change the contour path to start at the top of the stock. The result: 0.5" of my 201 rammed into the work piece during its rapid, oof. I was 1-2 seconds getting to the emergency stop so the machine was stalled/stopped by the crash for sometime.
I have checked the squareness of the gantry and it is fine, the spindle and bit are surprisingly fine, but there is a clicking noise coming from one set of wheels when traveling in the Y directions.
Is there a checklist or routine to go through specifically after a crash or should I just conduct routine maintenance?
Something something, be responsible (not lazy) with your file versions!
