what machind does one choose in CC if using a sainsmart 3020 pro?
thank you
Go into carbide create>Edit>Select Post Processor, then select Basic G-code.
For the toolpaths tabs, you’ll probably be closer to a nomad for speeds and feeds, but something you’ll have to edit for that specific machine.
ok thank you…im very new at this…i will look around…
