CM disconnecting during operation
I have the xxxl pro and just added the VFD as well as updated latest version carbide motion last weekend Everything seemed to work great until CM stopped/disconnetct about 1.5 hrs into a projected 2hr carve. All connections are solid. This happened twice now.
Anyone else having random disconnects. With the new cm update?
Prior to upgrading, I never had a disconnect in past two years of running the cnc.
Probably static. Have you grounded your machine? Search “Static” in the search box marked with a magnifying glass at the top of the forum. You will find lots of questions and several workable fixes.
Usually if this problem arises after a period of successful operation it is:
  • carbon brushes in trim router wearing down
  • a heavy load being introduced on the same circuit
  • lower humidity due to a change in seasons
Let us know what you find out at support@carbide3d.com — we have a 10-step plan which should get you up-and-running if it’s not one of the above (and let us know you checked the above so we don’t repeat).
