CM - option to skip tool change prompts.
For people without a bitsetter, the tool change prompts are just a waste time.
Hey Michael,
Just to be clear, you’re talking about tool change prompts when running your gcode file?
Yep, every file saved from CC prompts for a tool when run in CM. I don’t have a bitsetter, by the time the prompt is on screen it’s too late to do anything but abort.
You could switch to Grbl as the post processor under Edit | Select Post Processor in Carbide Create — I believe that removes the tool change commands from the G-Code.
