CM Remote Access
While the SW development team is preparing for the new CM upgrade that Rob Grzesek has posted, can Carbide’s SW team also fix the CM remote access control feature over a networked connection. This feature has never worked correctly and I have written several emails to the support team about it with documentation of this issue. Brandon of the support team confirmed it still doesn’t work even on the latest CM V6 and CC V7. A local network connected (wired ethernet) PC running CC V7 is supposed to link to a machine running CM V6 connected to the same network so one can send .c2d gcode from the PC running CC to the machine controlled by CM remotely. Can this be fixed as part of this CM transition effort to upgrade CM that Rob has posted?
