I’ve designed a simple bracket using one bit to cut the inside (1/8" Inventibles end mill) and a second bit (Carbide 3D #201) to cut it out of the stock.
CM went through it’s process and prompted for the #201 bit. Hmm, I thought, it must be cutting it out of the stock first, so I installed the #201, but it cut the inside out with it.
I’ve attached both the *.c2d and *.nc files, but it definitely shows a different bit for each toolpath.
What happens if you assign a unique tool # to it? (or at least one other than #201)
For the inner contour (and for the outer profile) note that cutting a slot as narrow as the endmill is wide results in near constant 100% tooling engagement — you should add geometry so as to cut as a pocket down to at least tab depth:
On the mac you can find the file by typing the filename (or even just “.nc”) in the finder’s search box, then right click on it and open the folder it is contained in (it’s one of the options of the right click menu that appears)…
