Hello. I have downloaded the new version of carbide motion and al of the sudden it is disconnecting from the cutter, Anyone else have this problem or is it in my settings?
The new create is not allowing to change bit parameters either. Just wasted my spindle
It should allow selecting and using endmills and entering new custom endmills into a user library.
If that’s not working for you, please let us know step-by-step:
- what you did
- what you expected
- what actually happened
and we’ll do our best to sort this out with you.
I try to adjust dept of cut and speed, but it still was cutting almost an 8th inch and speed was to fast. Changed the brushes in spindle this morning and finished the run. Cutting 3/4 plywood, burned up the 201 bit last night, thankfully had another on hand.
