CNC in furniture design
I just finished this armchair made of walnut and carbon fiber composite. I used Onshape for the design and Fusion to define toolpaths and execute on my Shapeoko 5. I did all the above in 4 months so the learning curves were steep!
I show below the screenshots of my project in Onshape. Basically I split the model in slices one inch thick. I then export each piece in Fusion and generate a symetrical copy. I then create toolpaths using adaptive clearing strategies. Each piece is a two sided job where I flipped the piece and use tabs throughout.
The rest is pure woodworking, i.e. glueing pieces together, creating jigs in Fusion to locate mortises for the joints, sanding, etc, the leg part is made of cherry then “skinned” with carbon fiber / epoxy.
The upholstery was not a walk in the park and would deserve a full presentation.
Incredible piece! Nicely done!
WHOA!!! That’s one of the most amazing pieces I’ve ever seen! Well done!!
You should feel proud of that piece. :+1:t2:
Amazing job on this! I’m sure you learned a ton on this project. That carbon fibre coating looks incredible.
Indeed! The software part was new to me and frustrating at times. The carbon fiber skinning is finicky and took several iterations to get it right, notably the seams.
Great work and finest details… AAA++
Fantastic piece! looking forward to more!
