Hi Julien,
Here are the logs, with and without soft limits enabled for the homing process:
Soft Limits disabled:
N0 M5
ok
N0 G4P0.005
ok
N0 G4P0.005
ok
$h
ok
N0 G4P0.005
ok
N0 M5
ok
N0 G4P0.005
ok
N0 M5
ok
N0 G4P0.25
ok
N0G0Z-5.0000
ok
N0G0X-210.0000Y-400.0000
ok
N0 G4P0.005
ok
N0 G4P0.005
ok
N0 M5
ok
N0G0Z-5.0000
ok
N0G0X-25.5000Y-388.0000Z-5.0000
ok
N0G0Z-15.0000
ok
N0G38.2Z-155.0000F800.0
[PRB:-25.500,-388.000,-95.640:1]
ok
N0 G4P0.005
ok
N0G0Z-91.3300
ok
N0G38.2Z-246.3300F50.0
[PRB:-25.500,-388.000,-95.620:1]
ok
N0 G4P0.005
ok
N0G0Z-5.0000
ok
N0 G4P0.005
ok
N0G0X-210.0000
ok
N0 G4P0.005
ok
Soft Limits enabled:
N0 M5
ok
N0 G4P0.005
ok
N0 G4P0.005
ok
$h
ok
N0 G4P0.005
ok
N0 M5
ok
N0 G4P0.005
ok
N0 M5
ok
N0 G4P0.25
ok
N0G0Z-5.0000
ok
ok
N0 G4P0.005
ok
N0 G4P0.005
ok
N0 M5
ok
N0G0Z-5.0000
ok
ok
N0G0Z-15.0000
ok
ALARM:2
GRBL_RESET
[MSG:Reset to continue]
ok
Grbl 1.1f [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
$X
[MSG:Caution: Unlocked]
ok
N0 G4P0.005
ok
G92.1
ok
G54
ok
G10L2P1X0Y0Z0
ok
G21
ok
G49
ok
G90
ok
$G
[GC:G0 G54 G17 G21 G90 G94 M5 M9 M56 T0 F0 S0]
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
N0 G4P0.005
ok
N0 M5
ok
G92.1
ok
G54
ok
G10L2P1X0Y0Z0
ok
G21
ok
G49
ok
G90
ok
$G
ok
[TLO:0.000]
ok
N0 G4P0.005
ok
M56P1
ok
$0=10
$1=255
$2=0
$3=2
$4=0
$5=0
$6=0
$10=255
$11=0.020
$12=0.010
$13=0
$20=1
$21=0
$22=1
$23=0
$24=100.000
$25=2000.000
$26=25
$27=5.000
$30=1000
$31=0
$32=0
$100=40.000
$101=40.000
$102=200.000
$110=5000.000
$111=5000.000
$112=2000.000
$120=400.000
$121=400.000
$122=750.000
$130=845.000
$131=850.000
$132=150.000
ok
I had the regular belt drive Z axis configured and only changed the params when I fitted the new carriage.
I set it to HDZ, re-applied the params with soft limits on, and same result. stalls 0.400" when moving down above the BitSetter. Soft limits disabled, all is ok.
Are there any drawbacks running the machine with soft limits disabled assuming the limits switches are fully operational?
