I assembled my XL and did the whole Hello World tutorial so basically ready to start cutting.
My router didn’t come with a collet. Wrote Carbide, but after a week of radio silence, I ordered the collets from their website.
Now that I have them, I have no idea how it assembles. The owner’s manual doesn’t show how to install. I can’t find any videos or tutorials for this part anywhere on the web. The collet doesn’t snap into the nut like the Shopbot I’ve used previously.
It looks like you have everything needed. Use the 1/4in collet, insert it into the collet nut, then thread on the router until it stays on. Then insert you 1/4in shank into the opening at the bottom, push all the way in and hold in place while you tighten the collet nut until the bit stays in place (ensure it is well centered in the collet). You will have to lock the spindle by pressing the little button and use the wrench to tighten (monkey tight not gorilla tight). You should be good to go.
It was stuck in there, I couldn’t get the end-mill in and had to remove the router from the rig and use an alan wrench to dig it out. It being wedged in there and being black made it seem like part of the shaft. Don’t I feel like a dope.
