Can I use an ER 20 collect in the new VFD? I want to be able to use a 1/2" fly cutter to surface.
The VFD which we have in our shop as an add-on:
as noted on the shop page:
Uses ER-11 collets
and the maximum size for them is 8mm (but we only include 1/4" and 1/8" — you’ll need to source your own collet in that size, and if desired a matching nut).
The HDM has an 80mm spindle (the afore-mentioned is 65mm) which uses ER-20 collets which would allow half-inch tooling — we have an 80mm mount and matching spindle in development for the SO5 Pro, but no idea on specifics beyond the diameter — check with sales.
I will note that 8mm tooling is quite a bit more rigid than 1/4", and is a promising possibility which has not yet been fully explored in terms of material removal rates — I will note that I have seen improvements in surface finish when using such tooling.
Might also be worth noting that, at Shapeoko spindle RPMs the tooling needs to be balanced and rated for high RPM. A single bladed fly cutter from a mill might provide more excitement than surfacing.
Yeah. I can attest to that.
I ordered the SST dragknife a week or so ago. They sent me the wrong shank size and had to send a new one. Weirdly they have the same part number and you can’t tel one from the other from the outside of the box.
Anyway I got the correct one tonight and in my zeal to test it I forgot to hit the interlock on the BitRunner to disable the router.
It spun up and before i could shut it down it damaged the shaft.
At least it didn’t fly off and take me out. I have reached out to see what that’s gonna cost me.
Hopefully it didn’t actually damage the router in any way but I was too depressed to check tonight.
Ouch, on the bright side though, it stayed assembled and didn’t throw any parts at you.
Yep. Stupid me.
I always hit the BitRunner disable after each job except when I don’t. If the speed setting reminder had popped up before the spin up that may have saved me as I would have noticed that I set the speed in the job at 1000.
Oh well. My biggest complaint is that it’s going to set me back another week or so on my testing with coroplast.
