Can someone please tell me what size wrenches I need for the collet? I have one that came with the machine, which fits around the collet nut itself, but I don’t have one to hold the spindle still while I turn the nut. I’ve just been using some vise grips, but it’s not an ideal solution.
Thanks!
I went and got a 12mm wrench, but it seems a tiny bit loose. Could just be my imagination, but I wanted to double check, are you certain the collet/shaft are metric? The bits etc that carbide sells for this machine all seem to be imperial.
@WillAdams, running the wrench gcode through CutViewer Mill and using CVM’s measuring tool, the wrench flats are 12.5mm apart. I’m using a 1/2" wrench.
@MrHume, all ER collets and collet chucks are metric on the outside. And it’s not like you’re installing a head bolt on a car engine–it does not take a whole lot of torque to retain the Nomad tools adequately. The wrench Will mentions is machined out of a piece of aluminum-plastic laminate, which says something about the torque level required…
