Combined two cc programs
I have two cc programs I want to compound me make one. I have the US Flag cc and the USMC eagle globe and anchor cc program. Reason for two programs was I wanted to get each to look like I wanted. I have finally got to cut like I want. Now I want to combine the two and make one us flag with the EGA. Is there a way to do that? Both are now cc files.
Yes.
If you open the eagle globe and anchor under the file at top left click on export svg and save it as an svg.
Then open the flag one, import the svg you just saved and use boolean to attach it to the flag however you want it to look.
If you need help just shoot me a message, I’ve made this flag in the past.
Of course, toolpaths won’t come across with the SVGs…so depending on how complicated those are, there could be quite a bit of work. There is a request to import entire c2d’s as objects - toolpaths and all. That would be really useful.
Thank you I will give it a try tomorrow and see how it works. I knew someone would no how to save the file as a svg. I knew that’s what needed to be done.
Thank you attaching tool paths isn’t going to be a problem at all.
