That is too technical of a question for me, but the experts will need to know what material you are cutting before they answer. Would also be helpful if you include machine.
A picture of the model would be great as well. If I had to guess I would say you probably could but it depends on the material, the specific compression tool, part geometry, etc. There are a lot of variables to this question.
I’d assume wood (probably ply) if he’s using a compression bit. I think it’d be fine. The adaptive will help chips clear.
Why the aversion to tool changing?
i get fuzzy edges on the pockets and on the final contour cut
i could use a downcut for all of the operations but that is not good for the adaptive roughing operation
