Got 3/4 way done with project and CONNECT TO CUTTER pops up and machine stops???
I restared all over and happened again about 2 min from being done? I had all electrical appliances off all light off and nothing running but router and machine ?
It sounds like an EMI-related disconnect. Did you have dust collection/shopvac running ?
You can contact support@carbide3d.com, they can provide guidance to identify the source of the disconnects and best practices to avoid them
It’s getting late over here so I will leave this in the hands of the rest of the community / Will for today.
What will help is if you can describe what you are cutting, whether it worked before without any disconnects, what details are different for those latest jobs, etc…
There is a section on this page for USB Disconnection. This is what I did to solve my issues:
Grounded my Router/X-Axis
Powered USB Hub
Anti-Static Dust Hose
You mention you are not using dust extraction, which could also be an issue. Have you tried running the job but with a hose in your hand to collect dust? (Obviously if you do this be careful and use a wand extension or something)
Please note that we have had instances where the accumulated static discharged when a hand-held dust wand was touched to the machine when attempting to vacuum by hand while the machine is running. Because of that and the inherent dangers, it should not be done.
Run the machine w/o dust collection, then vacuum up after when testing thus.
