Sorry, I’m not sure which one, but if you go to Etsy and search “STL bees” you’ll see at least three vendors for this STL. I suspect they are identical but I’d check the file size which may indicate whether someone is offering a reduced poly version.
All the samples I posted are small, the bees is about 50 or 60 mm square. If that’s the size you’re after let me know and I’ll post my tooling if you’re interested. The file has nice detail so best to use a hard, close grained wood but would also look good in brass.
