I’m in need of help on how to use the Convert to Curve under the Text feature in latest version of Carbide Create. I assume it will curve text? I’m currently using Inkscape to curve text, but if this is done internally, it would be way easier. Thanks!
No, the Convert to Curve simply changes the text from an editable text object, to a Curve object which may be node edited:
https://carbide3d.com/blog/merging-script-fonts-in-carbide-create/
Placing text on a curve/path is a frequently requested feature — I’m sure that there will be a big announcement about it when Carbide Create gets it.
For details on the new features see:
https://carbide3d.com/blog/carbide-create-v6-is-almost-ready/
