I downloaded a free version of VCarve 9.5 to do my school project at home but when I tried to convert it to .tap it wouldn’t work unless I downloaded the full version which is about $1200 here. The school has VCarve Pro 8.5 but I can’t load my file on the school computers because it was edited by a later version of VCarve. How can I convert my project to a .tap file without paying for the full version of VCarve Pro 9.5 ?
I think you’re out of luck.
http://support.vectric.com/aspire-questions/item/trial-versions-limitations
Got any details about the project? Was it ALL done in V-Carve?
Yea it was all done at home on the trial version. There’s no way of converting it to an earlier version ?
Not that I know of, but you can’t save or export anyway.
Just to be clear, you designed something from scratch in V-Carve?
There’s not much to the design part of V-Carve…couldn’t you just create it in Inkscape or similar and then import into V-carve at school?
I can save it in the 2D format but I can’t then change it to the .tap file
