Copy & Paste with Toolpaths and Layer Retention
Hello Carbide Create Team,
Currently, when I copy an object, the CC pastes it onto the active layer and doesn’t carry over the associated toolpaths. Manually reassigning each toolpath and layer for duplicated objects is time-consuming, especially for projects with multiple elements and layers.
Feature Request:
  1. Copy & Paste with Toolpaths: When duplicating an object, allow its existing toolpaths to be copied along with it, ideally retaining the same toolpath settings.
  2. Paste to Original Layer: When pasting, have an option to place the copied object on the original layer rather than defaulting to the active layer.
Benefits of This Feature:
  • Streamlines workflow by reducing repetitive steps for toolpath and layer reassignment.
  • Improves organization, especially in projects with multiple layers, by keeping design elements on their intended layers.
  • Enhances usability, making Carbide Create more efficient for complex or large designs.
Thank you for considering this request.
Best regards,
