Is it possible to copy a grouped text in Carbide Create (Build 743)
Yep, I selected two different texts. Grouped them, and then ctrl+c and then ctrl+v and it came out fine.
When I press ctrl+c, I don’t see a copy appear anywhere. I’m trying to make a copy of grouped text and move it off to the side as part of the procedure to make stacked text
You don’t normally see anything with CTRL-C. CTRL-V is Paste. It pastes near where your cursor is.
You can also use CTRL-D for Duplicate in CC. This will go exactly where your cursor is. (centered)
