I’m wondering if the nomad would benefit at all from a roughing endmill when cutting aluminum.
I recently had to remove a good bit of material (subjective i know, I’m working my way up to vince and the like
This probably took an hour or so with a very aggressive adaptive clearing strategy from fusion 360.
If I could reduce my cutting time 20% just by using a rougher that would be well worth the tool change. Not to mention the saved life on the fancy single flute datrons I’ve been eyeing ![]()
I’ve experienced the difference a good tool vs a bottom of the barrel tool can make in a finishing cut. Does this also apply to roughers or are they all pretty similar in operation?
I’d imagine the “nicer” roughers are just sharper and better balanced leading to lower cutting pressures/higher material removal rate than the cheap ones?
I’m going to try the corn cobs out and report back anyway but if anyone has pre-existing knowledge, I’d love to hear it!
