I would like to XCNC my own corner square =like the one found in Carbide.3d.
I have seen these but can’t find the pattern now.
Trace that one!
Scale it so the screw holes will fit your machine (Mine are 100mm apart), and adjust the lines to perfectly square. I would make it extra wide on the inside edges, since I would want
to skim cut them each time I mount it. The screws aren’t going to position it too perfectly. Or add a couple dowel holes on each side so it goes back in the same spot.
I used this one for mine
