I am trying to place a round over on a corner in CC, but for some reason the node is not there to be able to use the corner tool on the corner I need it on.
HELP!
HELP!
Post the file?
What dimension are you trying to round to? Have you tried slightly reducing it?
In node edit view i believe if you right click there is an option to insert a node. Maybe that will work for you.
I tried that and if you right click and press “S” it changes the node from a circle to a square but when trying to use the corner tool it remains the same. If this is supposed to work, there is a bug.
Version 729 answering the next question.
OK, I redrew the whole piece and it works correctly. Don’t understand why but it did work.
